- Oct 3, 2011
Hi, i need to print on A3 drawing and artistic paper in order to paint over my illustrations.
The paper i use weighs 200 to 360 g/m² which seems not supported from all the common photo printers.
I like the canon pixma 6550 but the specifications say it's possible to use normal paper only to 105 g/m² !!! However the canon special paper is up to 300 g/m² !!!
I'm confused...
Do you know a good printer with the features i need?
thanks
I'm confused...
thanks
