Hello,
My first language is Dutch, so excuse me if my English is not perfect
I have an HP Printer (HP LaserJet Pro 300 color MFP M375nw) that doesn't print as it should do. The documents are very bright and have lines.
What I know is that all four toners are almost empty, so that probably explains why the documents are bright. Now I wonder if only the toners need te be replaced or the fuser as well... The toners are very expensive but worth changing, but when the fuser needs to be replaced as well, than I will probably buy another printer, because toner and fuser together will be too much money.
I made an image of a black square in Word. On paper it is very bright with lines. This is a good example of what goed wrong.
I hope someone could tell me, after seeing this print, if it's only the toner that needs te be replaced or the fuser as well.
Thank you very much in advance!
