- Feb 22, 2015
Hello guys,
I need a color laser printer for running a graphics business. Now the printer should be able to scan, run on the network and support wireless functions (Bluetooth mostly). It's dimensions should be around 1 meter cubed and it should have the capacity to print/photocopy/scan up to size A3.
Can you suggest the best Canon printer and will it be economical to use a color laser printer for that matter?
Thanks
Thanks
