Brother MFC-J6535DW.
I changed the ink absorber pad. Part # D003B7
How to reset Machine Err 4600.
I know about holding down the Home Button to show the screen that will reset the machine with the correct sequence of events.
What are the correct key pad presses to reset copier to normal operation.
I suspect the correct key pad presses are specific for the MFC-J6535DW.
