Brother PT P300BT removing leading edge when printing.
Hi everyone,
My Brother PT P300BT P-Touch Cube Label Printer keeps printing out a blank 2.5cm/0.98" before my text and I simply can't find a away in which to change it. YouTube, Google Search, Brother website Support section doesn't offer any help, as do the leaflets that goes with the printer. I've only had it 48hrs and used it a fair few times, everything else works fantastically well, but this'll just waste my label cartridge over time.
Hopefully you can point me in the right direction. Thanks again.
Martin
Hi everyone,
Martin
I totally get your frustration with the blank 2.5cm mystery before your text on the PT P300BT. That's a bummer after just getting it. Have you tried reaching out to Brother's customer support directly? Sometimes they have specific troubleshooting steps or firmware updates that could resolve the issue.
Also check if there's any setting in the device itself that controls the margin or starting position for printing. Hope you get it sorted out soon!
Hi Daniel, thanks for that. I've tried getting in touch with Brother directly but there's no clear way to contact them other Customer Services Section, after section, after section. I'vee changed the margin setting, completed a firmware update, restarted, removed batteries and held the power button for 30 seconds just in case this might help. Nothing.
Possibly, my only option is to really play around with it some more, keep going online and hopefully I'll find out how to do it some day, maybe somebody here might even offer a solution, who know !! Thanks again.
I first saw this thread late October 2024; my answer may be too late for for outRAGEis, but I hope it helps others.
I have a Brother P-touch D610BT label printer. When I print a single capital M, the blank area of the label extends 23 millmeters ahead of the first downstroke of the M. There are three valid reasons (and one small miracle) for this on my printer, using a 12 mm wide black-on-white cartridge:
First, with the cover open, and looking down into the area of the print head (the 10mm wide white blade sticking up through the hole in the cartridge), the cutter blade on the left is 23 millimeters from the edge of the print head. It cannot get much closer, given the wheel between the cutter and the print head. The wheel must be downstream of the print head, so it can maintain tension on the tape as it passes the head.
Second, if you look at the print head itself (a magnifier might help) you will see that the black line (the thermal heating surface of the print head) is ANOTHER 1.5 mm from the edge of the white blade.
Third, if you look at the white border (the "kern") around the M character displayed on the screen, that projects ANOTHER 1.5 mm beyond the first black stroke of the M. Different graphic characters might fill the whole character box, and show up a little closer to the cut edge of the tape.
So, lets see ... 23 mm of tape to the cutter, 1.5 mm spacing to the print head, another 1.5 mm to the start of the M as displayed on the screen.
That adds up to 26 mm, yet the tape as printed is "only" 23 mm from the cut to the down-stroke of the M. 3 mm less waste than I naively would expect, given my measurements.
All the magic happens with the cover closed, so I can only guess ...
... that the mechanism actually pulls back about 3 mm of tape before starting to print, saving users three millimeters of waste per label. I can't imagine it pulling back any more tape without un-threading it left of the tension wheel, and jamming.
So, given the constraints, the mechanical engineers at Brother were VERY CLEVER and wasted less tape than a lazy engineer would.
IF YOU WANT TO WASTE LESS TAPE, concatenate many labels into one long label, perhaps with a period in the spaces between the labels so you know where to cut the tape with scissors or a paper cutter.
I make use of the extra tape in front when I print bracelets. That extra becomes the underside of the overlap area of the loop of tape. I use a sharp knife to score the paper backing off 23 mm of the right hand side of the tape; that closes the loop around the wrist of the patient/prisoner/victim. I do the same for medical inhalers, with " Mo Tu We Th Fr Sa Su " spaced at 1/7th intervals. Many clever ways to use (or abuse) these labels, and I hope to learn about more on printerforums.net or elsewhere.
I actually know the reason sadly I am on the same boat PT-P7108T
I know this because I work we have several different models and the reason is because my printer is missing a future called half cut. Half cat is a feature that is designed to slice your individual prints whilst being held by the bottom part as a strip and usually that first half inch kind of works like a pull tab. The wasted space when printing a Singer character is kind of the same reason princess that have the half cut feature not hold a smaller print whilst cutting ( which is supposed to be the half inch at the beginning ) unfortunately there's no fix just make sure when you buy a different model that has a half cut feature
