Canon IP3680 Printer Alignment Problem
Canon IP3680
New printhead, but problem existed with old printhead.
If you look at the attached image, on the "Q" value there is only one set of lines. The "Q" values from -5 to +5 are all the same. Not sure what the problem is.
Printer was given to me about 6 months ago. Before it didn't have this problem.
Also look at "A" "B" and "C". The alignment value is at -5, it used to align at +1 or -1.
Ignore the bad colors on the image, didn't scan to well. Colors are fine on actual printout.
Any ideas on what to fix, replace, or do?
Thanks in advance.
