Hi,
I've recently bought a Canon Pixma MP630 multifunction printer. Im experiencing a slight problem printing photos off.
I insert an SD memory card into the slot and i select the photo i need and the paper size.
The paper type i use for photos is the Plus Glossy II option, and the size is 4"x6", borderless print.
The problem i'm facing, though, is that when i print out the photos, it will not print out the full photo, its like its been slightly zoomed in as a bit of the top and bottom have been cut off, which is a bit annoying. The size i've selected is correct so its a little strange?
Is there any way to fix this?
Thank you for all your help
re4ryu
re4ryu
