I have an HP OfficeJet Pro 8600 N911a printer and I'm looking for cartridge chips on Aliexpress.com .
Can someone please suggest what is the best type of replacement chip to use on refilled cartridges ?
The choice are:
- show ink level
- do not show ink level
- auto reset chip
Product sellers always say that if the ink on the cartridge will be depleted, the chip will became unusable and should be replaced.
If the chip do not show the ink level how it possible that it will became unusable when the ink on the cartridge is depleted ?
The choice are:
- show ink level
- auto reset chip
