Changed my samsung clx fuser and still having problems
Hello guys, the printer were dealing with here is a Samsung CLX 3175
I had a paper jam before and whilst trying to remove the paper i damaged the fuser.
SO...I ordered and bought a new fuser, which i installed, but at the same time lost the clips as show below in the red circle, which are known as the actuator stacker.
So new fuser in, everything re-assembled and the printer still does NOT still work:( and comes up with the msg of "Scan Unit Open or Paper Jam 2"
Do you reckon this is being caused by the missing clips below?
Please someone help!!!!! LOL its doing my head in not being able to find the solution.
Perhaps you should try doing a full reset on the printer. Follow these instructions:
Menu, System Setup, Clear Settings and hit Clear.
