- Dec 11, 2012
My latest home office printer is an Epson MFP. Previous models were Canon and HP. I
always disabled the low ink warning because expensive cartridges printed page after
page until the ink finally ran out.
Just a wild guess, but it seems like these low ink messages are set to appear at 80% empty.
That means you're wasting very costly ink each time a cartridge is replaced.
I just read this warning at Inksaver:
https://www.inksaver.co.za/en/blog/Low-ink-warning.php
"WARNING: Epson printheads are very sensitive, so as soon as the printer gives you a
‘Cartridge Empty’ warning, you have to replace the ink cartridge as running Epson cartridges
to empty could damage the printhead."
Maybe I was very lucky, but using Canon and HP cartridges until they ran dry did not effect
the longevity of those printers.
If that advice from Inksaver is correct, should I junk my Epson cartridges when the low ink
warning appears? If the answer is "yes" that means the actual cost of Epson cartridges is
much higher than whatever you paid.
