HELLO.
I HAVE A DP2750DW PRINTER. AFTER I HAVE CONNECTED IT TO THE ROUTER THROUGH THE ETHERNET CABLE AND HAVING PROPERLY IDENTIFIED THE IP ADDRESS, I CAN PRINT AND SCAN FROM THE UTILITY IPRINT&SCAN BUT NOT THROUGH THE CONTROL CENTER (IT CANNOT SEE THE SCANNER).
I CAN NOT MAKE ANY DIRECT SCAN FROM THE MACHINE BECAUSE I CAN NOT SET UP A CORRECT PROFILE IN 'SCAN TO FTP NOR SCAN TO NETWORK MODE.' THE PRINTER SHOULD CONTEND THE SCAN TO PC FUNCTION ONLY WHEN CONNECTED THROUGH USB CABLE AND NOT THROUGH OTHER MODES. IS IT CORRECT?
SOMEONE CAN EXPLAIN ME IF IT'S POSSIBLE TO PERFORM SCAN WITHOUT SETTING A PROFILE ON THE WEB PAGE OF THE PRINTER, OR OTHERWISE HOW TO DO? I CAN NOT UNDERSTAND HOW TO CREATE AN FTP FOLDER SHARED IN WINDOWS10 AND CANNOT FIND CORRECT USERNAME AND PASSWORD.
THANK YOU.
THANK YOU.
