Eplson l130 ink loaded but not ink charging.. the only two less given. Both power & paper load blink
Epson l130 not ink charging
  • Anyone help
    Votes: 0 0.0%
  • Make fast
    Votes: 0 0.0%
  • Thank you
    Votes: 0 0.0%
  • Total voters
    0
  • Poll closed .
I bought one new Epson l130 printer...
Loaded with full ink and plugged to power.
Both power and paper load button blinking continuously for hours. Ink not charging and I couldnt get a print. Pls help
Hi Kishore, generally button flashing is due to the following:
1.- The paper is jammed in the rear paper feed. Please check this (see the manual about this issue). Also check that the paper is well posed.
2.- Multiple sheets were fed at the same time. Load paper in the rear paper feed correctly and press the right button (not the power on button)
If this does not work, shut down your printer. Unplug the power cable and the USB cable (if any). Wait a couple minutes and connect both cables. Power on your printer. Check all ink levels too.
Sometimes the issue is solved uninstalling and installing again the printer software.
Finally find out if your printer comes with some kind of test.
Hope this helps.
