Greetings, and thank you for taking the time to consider this issue.
Periodically my Epson Artisan 730 will indicate a paper jam and stop working.
There is not a paper jam anywhere. Not even a small piece of paper.
The following describes the scenario:
- Power button pressed ON.
- Normal startup indications appear for about 5 seconds.
- About 5 seconds after powering the printer ON, there is a very high frequency low volume sound.
- Sometimes there will be loud noises similar to the sound of plastic gears grinding.
- Then there is silence, and three flashing lights: the power indicator light, the WiFi light, and a blue light beneath the status display. The status display reads - "Warning Paper jam inside the product. Press OK to see how to remove the paper." Also on the front panel there is a green OK light about two inches to the right of the status display.
Just by luck in the past I was able to resolve the issue for weeks and months at a time. Once I blew compressed air into the printer openings front and back, and another time it just started working again.
A printer repair man tells me that there is a paper jam switch that can be seen by removing the duplexer. It is said to be a small plastic flag on the left as viewed from the rear, and this is a known issue that could be due to a weak or broken spring that is supposed to hold the switch in the normal position.
If I find the switch I plan to disable the switch.
Now that you have read about my issue, can you offer any guidance?
Thanks in advance.
Thanks in advance.
