- May 25, 2015
Hi all
Just wanted to ask if anyone has seen (and hopefully has a solution) for this print problem that just shoved up on my Epson Stylus Pro 3800.
When i print, one long vertical line can be seen on the paper (see attached image).
On the attached image i have used A3 and A4 paper size and as you can see, the problem is not that visible on the A4 (smaller of the two) paper. But it is in the same place.
I have been checking out the service manual of the 3800 Pro, and other websites, but I cant seem to find any corresponding problem.
One clue to why the problem does not show up as much on the A4 could be paper quality / thickness.
The A4 I use is much lower quality then the A3.
Any suggestions would be greatly appreciated
/Thomas
/Thomas
