Epson Stylus SX235W problem with black ink
Hello guys,
I have a problem with only black ink in my printer. The best to describe will be attached picture. It doesn't occur with other inks. It may be helpful if I say that I used non-original inks. However it never happened before. Any suggestions what is the problem?
Greetings and thanks in advance.
Hi Cloggen,
I'm a technician that is currently working at rihac. When you say you are not using original inks are you using compatible cartridges or a CISS? If it is a CISS make sure that the cartridges are full of ink and if needed re-prime the cartridges. Have you tried to run a few head cleans to see if that clears it up at all? I would be leaning towards it being blocked as the print seems to fade slightly as it goes on but that may just be the scan.
