Epson wf nozzle problems
Hi - any ideas on this one.
Have an Epson WF 2660 that showed all 4 nozzles were pretty blocked when I ran a nozzle test. I ran the clean nozzle process a couple of times which only showed a small improvement. I then used a syringe to carefully wash out each nozzle. Plenty of gunk came out. When the liquid came out clear, flushed with distilled water replaced the cartridges and ran test page - got no print at all, absolutely nothing. Also got a message that the nozzles may be blocked. Removed the cartridges again and used the syringe again to check if the nozzles would pass liquid - no problem water flowed through all the nozzles fine. But again when I replaced the cartridges no print at ll.
Anyone any idea what has happened
thanks !!
