- Jul 7, 2017
I have an Epson WorkForce 4530 printer that I have used for many years and it worked fine until I installed Windows 10 on my PC. Then everything went wrong. i know what the problem is I just don't know how to fix it or even if can be fixed.
Whenever the printer fails to print after I send the printer a printer command, it is because the printer is now offline.
Now I know what that means, but my printer goes offline at the slightest hint or provocation. By that I mean it seems to always be offline.
Sometimes it does not need any provocation to go offline t just happens!
I am using Windows 10 and this issue started with Windows 10. It seems to never have a permanent setting for Windows 10 in using printer online. if the printer is left alone for any amount of time, it will go offline.
Ho do I fix this?
Any help appreciated. Thanks in advance.
Respectfully,
Newport_j
Ho do I fix this?
Respectfully,
Newport_j
