- Jan 4, 2012
Hi,
Have a HP C6180 Multifunction printer.
I am no longer getting a link (or even link light) on the hard wire ethernet
port (another network device plugged into the same jack, with same patch
cable works fine)
I have reset the network settings from the menu, done a hard reset of the
device and even pulled the internal battery to totally wipe the settings.
The actual reason I opened the printer and found the battery was I thought
that the ethernet jack on the printer might have broken loose from the PC
board, but that is not the case.
The wireless still works.
Before scrapping the printer I just want to make sure that there is nothing
else I might be overlooking.
Thanks
cable works fine)
Thanks
