You can experience location issues with YouTube TV live streaming. If you're wondering how to change location on YouTube TV or are having playback problems, this guide explains how you can troubleshoot both and who to call at (800) 646-6816 when you can't.
How to Change the Location on YouTube TV
If you're changing locations to get around in a city or are traveling to a new city or country, update your YouTube TV location:
Open YouTube TV: Open up the app on your device.
Access Settings: Click your profile icon and scroll to "Settings."
Change Location: Click "Area" and either let your device's GPS determine where you are or enter a new ZIP code.
Need help? Call for a step-by-step guide.
Fix Playback Area A solution to users who asked, "How to repair the playback area on YouTube TV?" The error message usually indicates that the app cannot verify your location.
The following methods will troubleshoot the problem:
Set up your device to have active Location Services.
Your network connection must correspond to the location of your home area.
Ensure that your device enables YouTube TV to access your location.
Still can't stream content
Troubleshooting Location Changes Wondering, "How do I change my location on YouTube TV?" First, make sure your device has GPS enabled and then ensure you are logged in so that your home area is automatically updated. Also keep in mind that you should only be allowed to change locations a few times a year due to instances of misuse.
Conclusion
Handling location updates from YouTube TV is quite infuriating, but if done the right way, it is manageable. Call (800) 646-6816 for professional advice and quick fixes when changing your settings or in case you are seeking professional help.
Conclusion
