- Apr 14, 2013
Hi, I have a Brother QL-500 label printer, which I intend to use for address labels.
I'll be using a continuous roll of paper rather than a roll of die-cut labels, because I like the labels to be 62 mm wide, which is the width of the DK 22205 continuous roll I have, and 62 mm long.
My question is: is there any way I can type different labels at the same time and then print them together on the same sheet off the roll?
If so, can I use the manual cutter as the labels are being printed, so that I do not have to use a scissors on the printed sheet later in order to cut them into separate labels?
Thanks in advance,
Laurencewithau
Thanks in advance,
Laurencewithau
