Help with buying a printer please.
It will be the first time I buy a printer for myself so please bear with me. Usually I just go to a friends house and print my stuff there :p
I need a printer with a scanner that is compatible wirelessly (via WiFi) with my Macbook Air. Preferably a black and white printer or at least a printer that will run without the color ink because I really don't use colored documents especially at work.
Also, there are so many printers out there with so many cartridges that It is so hard to find one with the most economical ink. meaning a printer with an ink cartridge that can give me more bang for my buck.
Please tell me if you know a printer with all these specs. Thanks
BTW I heard Brother has the cheapest ink?
