- Dec 5, 2016
Hi!
I think I need some help and advice to get my printer to work again..
As you guys may know has this printer ink cartridges on one side of the printer and with tubes to the printhead. In the place where the ink cartridges are, there are a "pump", it pushes on a "window" on the cartridge.
The problem I have is that the printer does not print magenta. Or infact it prints nice some pages with photo, and then it stops printing magenta. It can seems that the pump doesent give the head enough ink.. If I remove the head and use a syringe to suck some ink out, it works a little before the ink dissapare.
BTW i do not use genuine ink, but the compani I buy from is serius, and ink to other printers works excellent.
This is not a printer that I use alot, mayby every 3 month, but the head works nice in the beginning of every printing I do.
