I have a gently used HL-2270DW printer that has developed a problem feeding paper from the paper tray.
I have already replaced the paper feed rollers and cleaned everything.
The paper is picked-up fro the tray and pushed up towards the manual feed slot, but seems to hit something on the way to the printer. If I pull the paper tray out very slowly I find the leading edge of the paper has been fed up into the printer. If I pull the paper tray out, I can manually feed the paper up into the printer and the sheet will print fine. The manual feed slot also works just fine.
Anyone got an idea?
Thanks in advance for the help.
Anyone got an idea?
