There are 2 ways to increase the print speed of your printer, first by managing the choice of spooler options. Basically the printer spooler works to hold the data you want to print for a few seconds and then sent to the printer to print. By default on most printers, the printer spooler option is enabled but you can turn it off to determine that the file must be sent to the printer and not spooled.
Following these are the options for spooler printer, there may be a number of different ones depending on your printer brand, but on most printers you can deactivate it by going to the Start menu, Settings then Printers. Now right-click on the printer icon you are using. Click Properties and select the Advanced tab. Next click "Print directly to printer". remove the dot in the selection.
Secondly, you can increase print speed and save ink in the printing process by reducing print quality. When print quality decreases, the print speed automatically becomes faster and ink removal becomes more efficient. but actually the steps are the same. Select your Print Properties menu and look for settings to reduce print quality. You can set it up instantly by changing the Normal to Fast Draft setting. Another way you can use to increase print speed is that you can try to print documents from the web without using graphics, so it's just characters, and add RAM to your printer.
