How to show current USB samsung laser printer firmware version (from Win 7)?
I bought recently a Samsung laser printer M2625D and connected it through USB cable.
It works (from my 64bit Win 7 system).
Now I want to check the current firmware version.
How can I achieve this?
if possible with built-in Win 7 tools or 3rd party tools.
I want to avoid to install some more bloated Samsung "easy" service software.
Thank you
Peter
Firmware version can be checked via 1- Printer Configuration Report, Or 2- Easy Printer Manager Or 3- Samsung Printer Diagnostics
As you dont want to install any software, pls check by taking configuration report
check below procedue
Press "Stop/Clear" Button continuosly
First it will blink slowly then fast...
Once it blinks fast release button to get Configuration Report....
