just installed drivers and indicated I wanted to set the printer up to connect via wifi using a USB cable to get started. when asked to reboot, the (windows 10) PC did, but the display was weird with icons and windows missing things like, well, any text at all.
I rebooted again and all seemed normal, except that the printer is now connected via USB. I checked the printer and found that the IP info was all set to zeros. from the control panel on the printer I was able to run a wizard that offered to switch the interface to wifi. it then connected to my network with a DHCP-assigned IP address provided by the router.
Printer still worked (print, scan), but when I disconnected the USB cable the driver reported that the printer was not available.
How can I adjust the driver to know that the printer is now wifi accessible?
