Hi I am new to this forum and have heard that if any forum can help me, this is the one to be in. I have a HPC7280 all in one printer and am having problems with the upper paper feeder, ADF. If I try to send a fax or copy documents it keeps telling me to "reload document and then restart job". It sees the paper being loaded because it displays origional loaded on the screen and I get a confirmation tone. I have cleaned the rollers and the all the gears are ok. I have tried the resetting/restoring as per HP's support and still no paper gets fed into the ADF. The printer is only 2 years old with very minimal use. I havent changed paper thickness/quality- its always been the same.
Any help will be greatly appreciated!
Thanks,
Tony
Thanks,
Tony
