- Feb 15, 2021
I'm afraid that removal of this readily visible part must be done from the "top down" - the entire printer has to be disassembled to gain access.
I'm trying to find a way to do it quickly by cutting, bending, and even discarding portions of parts that are in the way.
I have 4 of these printers that need this repair ranging from gear broken to sliding on shaft. (Sliding on shaft I'd like to "slide it over" and then JB Weld it back in place RATHER THAN Super Gluing it. I know SG has been tried before - did it work?)
Thanks in advance,
Tom
Thanks in advance,
Tom
