HP Printer is not sorting copies when printing multiple copies
Hello,
We have an HP Color LaserJet Flow E87660 and I cannot find the options to sort the multiple copies in a zigzag way.
I don't know the correct term for this.
Now all the copies are print one above the other, and we need to manually separate the different copies.
On our old Xerox, the copies were printed in a zigzag way, so that every copy was easy to pick.
Thanks for your advice.
Greetings
Lainkes
If you need a printer that prints the documents in very less time and cuts out the hassle, then the HP OfficeJet Pro 9015e printer device is for you. You will fall in love with the amazing functionality and its smart scanning speed with the wonderful printing quality. There is an app that you can use from your mobile and have the ability to organize, scan, copy, and print the documents on your HP OfficeJet Pro 9015e printer machine. It means that there is no more such awful queuing on the printer device waiting for the turn. This printer device comes in a surprisingly stylish box with full modern technology.
The HP OfficeJet Pro 9015e printer device is mainly designed for small businesses or small office workforce. This printer easily fits in your small office along with your computer system or any such type of device. You can also take a subscription to Instant Ink, and if it works on the HP+, then you will be notified by the mail to replace the ink cartridge before you run out. If you want to take a subscription to HP+, then there is an offer of six months which means you get six months of free subscription. You will also get an extra year of warranty for your HP OfficeJet Pro 9015e printer.
You are printing the documents, and suddenly it starts printing the pages blank. Then, you may straightaway think that it has run out of ink. You can refill the cartridge or replace it, depending on the printer you use. But this is not always the reason; there can be more possible causes. No matter what causes the printer to print the documents blank, you can quickly resolve it. This article can be your helping hand in getting the answer to your question, "why is my HP printer printing blank pages"? Here you will look into the effective and quickest ways to fix it.
Solutions to Resolve HP Printer Is Printing Blank Pages​
You have given the correct print command, but the printer prints nothing and gives you blank papers. Whenever this situation comes, you must check the reasons behind it and fix it. You can perform software or physical check of the printer.
