HP PSC 1210 help!
Ok, so I have a printer I got free many years ago with a laptop I bought, maybe 5 years ago. It's always worked great, no issues at all.
Today I was able to only print one sheet, then the 'out of paper/stuck' light turned on. The issue is it's not even pulling any paper in. There's little to no dust in there, all rollers move freely and I'm not seeing anything that is causing it to just not pull the papers.
Is there anyway of fixing it w/o taking the whole thing apart and hoping a little fiddling will fix it??
Hello,
I would try what is called a cold boot. That can help initialize the process. The steps are listed below. Additionally, what kind of print media are you using?
Remove cartridge(s)
Shut down printer and unplug from wall.
Let sit without power for at least 10 minutes.
Restart the printer with no cartridges installed.
When “No Cartridge” error displays, install Ink cartridge(s).
Let me know if this worked to assist you.
Thank you,
Adrian Watson
