I am using MS Word and when I change the fonts, after writing it automatically changes to default. How should I fix this?
To use your favorite font in Word all the time, set it as the default.
  • Go to Format > Font > Font. You can also press and hold. + D to open the Font dialog box.
  • Select the font and size you want to use.
  • Select Default, and then select Yes.
  • Select OK.
Anchor fonts
