ADSL-internet gateway with 4 LAN sockets (IPTV, laptop, switch, printer)
FS-1030D with IB-21E LAN printserver via LAN cable connected to 1 of the 4 LAN sockets on my internet gateway. Static IP.
My desktop via cable via switch to internet gateway, Win 7, static IP, I can print from my desktop, sometimes it seems to take longer than earlier until the printer starts to work (?).
Laptop of my wife with Win 8.1 directly connected to another socket on the gateway. My wife's laptop could also print but stopped doing so some time ago. Several deletions of Kyocera drivers with Kyocera deleter software and manually removing stuff from the registry, reinstallation would not help. During installation of printer Windows sometimes sees my network printer and sometimes not. Even after apparently successful installation of the printer I could not get a testpage printed.
Pinging from desktop to the printserver gives peculiar results. Once 0/4 packet, once 2/2 packets, once 3/1 packets, once 4/4 packets. When pinging several times it seems to wake up and responds with 4/4 packets. After a while again dropping of packets. Still printing is possible.
Pinging from laptop the same. Printing not possible.
Both computers have Bitdefender antivirus software installed. Deactivating it does not help.
LEDs on printserver card indicates connection (green permanent) and data transfer (red blinking).
Connection to webinterface of printserver with browser possible on both laptop and desktop despite not pinging normally.
What I have tried without success
LAN-cable between printer and gateway replaced with a brand new one out of the closed plastic bag
Hard reset of printserver card with jumpers on it
Soft reset to factory values via webinterface of printserver
I changed the LAN cables' position on the 4 sockets of the internet gateway.
I treated the contacts of the printserver card with contact cleaner and reinserted it several times to clean the contacts.
What I still can try ist to take the same card out of my printer in my condo and switch them.
So I am quite desperate to get my wife's laptop access to the printer. Any suggestion for a solution?
