Kyocera ECOSYS P8060cdn Maintenance Mode (resetting cassettes)
I was wondering if anyone had any knowledge on how to access maintenance mode or service mode on a Kyocera ECOSYS P8060cdn? I talked to Kyocera support about cassette 1 and 2 not working, and he said that it may be due to not taking out the yellow plastic clips that hold the cassettes in place when being moved. He said it needed to be re-enabled through maintenance mode. Any help would be appreciated!
Hii orenk!
You can perform the factory reset of your Kyocera ECOSYS P8060cdn printer to check it helps in fixing the issue.
  • Go to the printer control panel, select the “System Menu” or similar button to access the main settings menu.
  • Then, move to the Reset menu.
  • Next, click on the Factory Reset.
  • Tap on Reset once again to confirm the action.
  • Now, wait for the printer reset to complete.
  • Finally, check if you are still facing the issue.
