i replaced a transfer roller due to an employee using "rubber rejuvenation" spray on it which resulted in smeared prints.
However, even after I replaced the transfer roller my prints are still smeared (see picture). I assume it is because the oily spray has gotten onto the smooth roller that the transfer roller presses against. I attached a picture of this smooth, hard roller that has what appears to be contamination on it.
How can i go about cleaning this roller when it will not rotate? Is there an easy way to allow this roller to rotate so it can be cleaned? Should it even be cleaned?
PHOTOS
Thank you!
PHOTOS
Thank you!
