Laser Printer without Wireless
Hello there,
I am looking for a source, web site, Forum, that can help me find Laser Printers that do not have any Wireless, WiFi, Radio, Etc
Some source that identifies those printers
Any ideas?
Thank you
Bruce
http://www.printerbase.co.uk/acatal...oCICsrPnTDl4N-M6b1_zMtZAaPGvzNF_GkaAgTk8P8HAQ
I can recommend this printer I think it is what you are looking for and you may find it even cheaper. I have been using this for years. See my other post, it is very easy to refill and the toner costs 25 pound a kg which will give many, many thousand of pages. One can buy paper for under 2 pounds fifty a 500 ream. It has never ever caused any problems and even if you have to change the cartridge they are only four pounds 43 pence on ebay if delivered to argos. A cartridge if refilled correctly should last a very long time.
