this time to ask about printer.. i saw no dedicated area in this forum is for printer, so i guess ask here is correct ?
so now, i want to buy a printer ( 90% laser printer as i wan stable ink and i NEVER use color)
of course i want a mutipurpose printer, can fax, print, and copy.. i survey around, those laser with fax need at least 6-700 hundred, AT LEAST. so i wont go for that, i will be going print and copy..
so what the best printer for me? of course, cheap in the first cost, last long(no breakdown) and easy for toner replacement(easy to find, cheap, replace etc)
and now, i started to explore fax console(use windows to send and received fax).. is it that i use this program so that i can use the printer without fax function? thanks
