Lexmark printer with a build up of Label glue
I have many Lexmark printers MS81x and MS82x that print labels. After a while the glue from the labels builds up on the paper guides inside the printer. I've tried goo be gone, alcohol and clorox wipes. All work a little bit but it takes a lot of scrubbing to remove the glue. Any ideas on cleaners to remove the label glue?
