Making Printing Darker on Samsung SCX-3405W
Can be changed with easy printer software or with printing preferences.
1. download easy print manager from samsung website then go to devicesettings->printer option then change darkness.
2. Go to device and printers in windows after that right click your printer then printing preferences then graphics
Forgot to mention printer is on OS X El Capitan.
Regards,
Gren
Hi Gren,
Pls check if you have installed the right version of Software as its also available for the MAC OS 'X'
XIP
Check below link for installation support:
http://support-us.samsung.com/cyber...rom_osc=&idx=469101&modelcode=CLX-3305FW/XAC&
go to devicesettings->printer option then change darkness. (Note:- Device settings is visible in advanced mode, Take help from above mentioned link screenshot)
