Need help converted L1300 ecosolvent printer print smudge
Im using an epson l1300 converted to ecosolvent ink. After cleaning . It prints out smudged in black. Im cleaning it with a solution. Im not sure if i put too much solution.i tried removing some of the solution by absorbig it in cotton balls with no luck. Any fix for this will help. And tips so this wont happen again if i ever fix this. Also i would like to know the cause of this. Thanks.
This is where i put the solution and i absorbed the solution there using cotton balls
And here are the smudges.
