- Sep 10, 2013
Printer worked fine until installed a new capping pump assy. the old one was pretty bad shape making light gear noises.
I did about 20 head cleaning, i can hear the pump working but no discharged ink in waste bottle, it wont lay any ink down.
I have changed cartridges as well, and print head, if I flood the capping caps it will pull it down into waste bottle but it wont
pull ink down from the head. I have also checked the head cable connections, cable looks good,, checked fuse No. 1 and
fuse No. 2 and it;s not blown. Can anyone help??
