- Oct 10, 2023
Hello...
I have a bit of a problem and would appreciate some help if possible..
My trusty 7900 died recently so I had to buy a new printer and went with a 7500
I was using shiraz rip and transferred that to my new printer.
I thought it was going well until i tried printing a poster and noticed the text was not great.
I have tried all sorts of profile and printer paper settings but just cannot get it as it should be.
I note the highest profile I can select for German Etching is 1200Q
I used to use 1400 sending a 300dpi file which worked perfectly.
In desperation I tried downloading edge but that just will not work on my mac for some reason.
Do i need to download drivers?.. I never need that before as the RIP took care of it.
Is there a way I can have a simple life again ?
Please can anyone help ?
I print on Hahnemuhle German Etching, Photo Rag and Fotospeed Matt Ultra
Thanks so much and apologies for going on !
