Need to make an Epson Stylus PRO 10600 DYE work on W10.
Hello;
I've acquired a larfe format printer for my office and can't make it work in my Windows 10 computer.
It's an Epson Stylus PRO 10600 DYE, which has no drivers after XP. They sparred a computer with Windows XP with witch I can correctly use the printer.
The deal is I need to be able to print directly from my computer, so I can make the printer work on my Workflow (We make CTP plates and bla bla)
When connecting it via usb it shows up as USB PRINTER on Other Devices
What I have tried:
Install XP drivers and see what happens: Never detects the printer.
Install XP drivers and manually select the port (USB0001): fails
Add printer manually from Printer & Scanners, selecting port USB001 and try to add XP drivers: no result
Add printer manually from Printer & Scanners, selecting port USB001 and select some random Epson drivers from Windows Update: I got to print but my max size was A4.
Add printer manually from Printer & Scanners, selecting port USB001 and try to add other Epson Large Format Printer drivers with W10 supports: driver detects it's another printer and won't work
Searched for Universal PCL Drivers from Epson: won't recognize it
Get the XP computer on the Network, solved a lot of problems till I could see everything on the Workgroup correctly, and then shared the printer. When connecting to the printer from W10 computers it says it can't find a driver for it.
Please, I need some help. Is this really Impossible?
tl;dr: Need to make an Epson Stylus PRO 10600 DYE work on W10.
