- Feb 7, 2014
1. Budget: £150-£250
2. Preferred brand: None, but used Dell for the last few years
3. Brands Not Preferred: None
4. How many pages do you print per day: 100 ish
5. Do you want your printer to perform other functions: Not necessary
6. Preferred website for printer: Usually use Amazon as good customer service
7. Do you want your printer to have WiFi capability: Just needs to be networked, not wifi
8. Do you want your printer to have full color or black and white: Prefer colour
9. How much do you currently spend on ink/toner: Too much, not sure. Just buy it when needed. Always use replica cartridges (IJTDirect)
10. Do you print high quality or high resolution documents or photographs: No. Just need colour for our invoices to keep the branding correct (just spent alot on re-branding and don't want to start making the logo black instead of purple)
11. Additional question is how much extra is colour compared to monochrome? is monochrome cheaper to run? Or will colour just use the small amounts of colour toner needed? As colour and black cartridges have been the same price in the past
Was looking at a Dell B2360dn (but monochrome) and a Brother HL-3150CDW
Is it worth spending a little extra and getting a Lexmark CS CS410dtn
Thanks in advance for your advice.
Hate printer shopping!!!! Too many salesmen that talk rubbish, grr
