OKI ES9431 - Faded Print Problem
I have this problem both on Black Only (K) printing and on CMYK color printing.
The colors come out Light, the toner is not dense. (The attached photos are of Black and White printing, but if I print in color the result is the same with the 4 colors, washed out image.
This happened after having Disassembled, cleaned and reassembled the "Black Only" Drum Cleaning Blade (transfer belt).
Assuming that it damaged the Black Drum, I can't understand why the problem occurs on all 4 colors.
Everything was fine before this operation. I only disassembled the blade, cleaned it and reassembled it, I didn't touch anything else nor removed the toner or other rollers.
After 3/4 days the OKI is back to printing regularly. After another 5/6 days I have the same problem.
Could it be a problem with the 2ND TRANSFER ROLLER the one after the belt and before entering the fuser?
I can't find any solutions, please help me.
