Pin came loose on XP-215
Hi all,
After trying to remove a paperclip fallen into my XP-215, I unclipped a sort of thin metal pin. It is located inside the printer, on the far left side, and goes inside a pinhole, through the side wall.
Since then, the roller spin super fast when I turn the printer on, then all lights flash.
I don't want to throw my (cheap) printer away for this! Any idea, please?
Mika
