- Jan 15, 2016
I've changed my Virgin Media Hub and am trying to set my MG3200 printer to this new wireless connection.
I follow the same Wireless Connection procedure in the Setup Guide but the printer does not detect the hub in WPS mode. After several minutes it always fails with an error code E, 2, 2. This is not one of the error codes listed in the Setup Guide Troubleshooting list. My other devices, e.g. Smart TV, connect in WPS mode without any problems, so I don't think the hub is the problem.
I successfully connected one computer to the printer using the USB cable, via Windows 7 driver update, so it appears to be just a wireless issue.
I've also un-installed and re-installed the printer driver and network tool, and restarted the hub, but this makes no difference.
Please can you help?
Thanks.
I've not changed the factory default settings (below):
Super Hub 2ac has 802.11ac support.
Security Mode WPA Auto (2.5GHz) and WPA-PSK[AES] (5Ghz).
Thanks.
