I have an Epson XP 410 printer. It has worked without issue for the past 2 years. I use the google cloud print feature since I have a chromebook. I went to print something yesterday and it said printer was offline. I went to the printer and it was off so I turned it on. 20 seconds later it turned itself off. Turned it on about 5 times and same result, it turned itself off. I started messing around with it. I turned my router off and then turned the printer on and it stayed on. I turned my router on and the printer went off. I left my router on and turned the printer on but disable the wifi on the printer and it stayed on.
So for some reason anytime the printer tries to connect to wifi it turns itself off. My sister has the same model printer, its being stored in my basement. I hooked up hers and same exact thing. Hers is on a much older firmware also.
I'm not sure if its my router somehow or the epson printers. or something in google cloud print software that doing it once its connected. Its really odd though.
Any ideas?
Any ideas?
