The title says it all. I have tried everything: updated all firmware, software, drivers...nothing works.
I tried using the Epson troubleshooting function, and it shows that all of my drivers and software are updated.
After using up the Wi-Fi Setup wizard, it prints the network connection report just fine, no problem*, but then, if I try to print a normal text document (using OpenOffice Writer), it shows the printer as being offline.
*the signal strength is reported as being 'excellent.'
I tried uninstalling, then reinstalling the printer...no good.
Everything is fine when I plug the printer into my laptop with a USB cable, but it just won't print when using Wi-Fi.
Any help would be greatly appreciated!
