Printer suggestions for small-scale production setting
Hi,
I'm looking to purchase a printer, and I'm looking for guidance on suitable models.
- The printer is for use in a small-scale production environment, where it'll be used to print 8 photos evenly, without gaps on A4 pages (2 columns, 4 rows (portrait)).
- The pages will have a GSM of between 200 and 300.
- As far as I'm aware the printer will need to support borderless printing on A4 pages to do this task successfully.
- The images will then be cut apart using a trimmer.
- Budget: ~500 EUR
Those are the requirements that come to mind, but it's very likely I'm overlooking important considerations.
I'd be very grateful to hear any suggestions you have, and also any considerations you think I'm overlooking in terms of printer spec/requirements etc.
Thanks very much,
B.
Canon PIXMA PRO-200: Excellent color, borderless A4 printing, supports thicker paper (~600 EUR)
HP Envy 6055e: Budget option, decent for photo printing (~400 EUR)
I'd be interested in knowing your thoughts on the Canon PIXMA G640 MegaTank
