Pro 9000MKll unable to print on A3+ excessive noise
The problem is strange. Using Ilford Smooth Gloss paper. The image will start to print OK but very quickly the printer makes a very loud noise like a ratchet for a second or two, prints a bit more then another noise. I have to abandon the print job because it sounds as though the print head will be destroyed. Canon support by telephone have no suggestion to make - has anyone here had the same problem?
Roger
